Why is this happening?
Sunday I noticed a popping sound coming from the TV. About an hour or so later the screen went out but the sound was still active. Later that night I hit the menu button on the TV and the menu popped up then the screen went black again. The next morning I turned the TV on and it was working until today. Same issue. I noticed after taking the back of the TV off that the blue light on the board comes on then slowly dims off. Not sure if that's something to be concerned about. Can someone please help. I'm trying to see if it's worth being repaired or getting a new one. I purchased it back in 2012.
Comments:
What about the issue with the screen going out? I can't see the menu to upgrade the software
by
Thanks. I opened it up and didn't see any bugs or residue from any. I'm really unsure of what to look for regarding shortages. If anyone can provide me a link or possible places I can take the TV to in Chicago please share the info. That would be greatly appreciated. I really don't want to purchase a new TV since I'm hardly home and I don't feel it's an extreme problem but who knows....
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I can think of two possibilities. the first is that a bug crawled into the TV and got across some high voltage in the power supply. The second is something is shorting. If you feel ok abut looking around the inside you might look for a bug (insect) but if you find one, only use non metallic item to clean it out. Leave the TV unplugged for 30 minutes before opening. I don't know what the blue light is, so no help there.
Otherwise, if the TV quits, I would get a new one since 42" size are not very expensive and probably have more features.
Score -1
Add a comment
Most Helpful Answer
@goldengyrl you did not tell us what your power LED shows. If the power LED is green and the backlight is on but you have no video or onscreen menu start off by checking to see if you have 12 V on pin 6 and 7.
. If you do not, then replace the power board. If you do have 12V there, process to check with this:
If you need help with any of this, post some good images of your boards with your question. For that use this guide. you also want to explain to us exactly what happens with your TV. Let us know what the Power LED shows, if you have an onscreen menu etc. The more detail you can give us, the better.
Not sure where you could get your TV fixed, but I am certain it will be more to get it fixed than if you just replaced all the boards inside your TV:-) Give it a try.
Score 1
Comments:
THANK YOU SO MUCH.... when I hit the power button the green light comes on and stays on. As a matter of fact around 1am I turned the TV on and it was working for about 30mins then went back out. I'm going to follow the steps you sent me.
by
Add a comment
The blue light slowly dimming will be the capacitors and is nothing to worry. I've had this problem before and was rectified with software upgrade found on the menu screen
Score -1
Comments:
A firmware upgrade fixed popping sounds?
by
Add a comment
Add your answer
Jessica will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 73
