Show massage on display " E100-0001"
Shows error massage on "E 100-0001"
Score 4
Comments:
Can i get a display board for canon mf4820d printer by online
by
Please tell me the price
by
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Hi,
Try a power reset and see if this resolves the problem for you.
Switch off the printer if it is turned on, then switch off the power outlet and remove the printer's power cable from the outlet.
Wait for 5-10 minutes.
Reconnect the printer's power cable to the power outlet, switch on the outlet, then switch on the printer and see if it performs normally.
If you get the same error message after doing this 2-3 times then the problem is either in the Laser Scanner Unit or the Engine Controller Board (one of these will have to be replaced).
Score 4
Comments:
by
Add a comment
canon image class mf 4412 printer error 201-0001 turn of the main power
and the same problem canon image class mf 4750 error 101-0001 turn of the main power how to solved the printers problem i will request the problem solved
Add a comment
Add your answer
esourcecomp will be eternally grateful.
Past 24 Hours: 19
Past 7 Days: 109
Past 30 Days: 498
All Time: 5,238
