Problem with home button and main camera
Hi folks!
I was hoping that some of you could help me with my strange problem with Iphone 6.
Namely, last time I opened my phone to fix front camera crescent moon problem, when I finished work on camera, I put flat cable connectors (LCD, front camera, home button and touch) in place on main board and closed phone frame. Nothing was damaged, scratched etc.
After that repair, I am having strange problem with, sometimes, unresponsive home button (home button wont wake screen, double tap does not work, wont exit app etc.), also, flash and back camera sometimes just wont work.
When this problem occurs, for example when I enter camera mode, I got yellow triangle with warning that indicates warm flash unit, besides the fact that I didn't use flash or camera,
After, for example, hard reset or just phone shut down, everything is working fine... for a half day, and after that the problem is back...
Could someone help me with this issue ?
Thank you in advance!
All the best
Alex
2 Comments
Sounds like there is some static or power surge build up within the phone. Might be worth unplugging the battery and holding the power button for 15 seconds then plugging the battery back in and see if that helps.
Camera IC sounds like it is getting overloaded / faulty and the home button issue not really sure what is causing that.
by Ben
Dear Ben,
Thank you very much for your suggestion and help!
I certainly try to do what you said.
Do you maybe have any other suggestion ?
All the best!
Alex
by Alex
