Why is it that my phone has no sounds?
Score 3
Add a comment
1 Answer
Chosen Solution
Have you checked that you are not in Airplane mode?
Press and hold the Power button on the phone to show the pop-up menu to select from ''Ringer mode /
Airplane mode / Power off / Reboot''
Have you checked the Sound settings in your phone?
Go to Home > Settings > Device > Sound
Tap to enter all the available sub headings, Volume, Phone Ringtones, Default Notifications etc., to see what the settings are.
Update (11/23/2016)
If you can hear people on a call, but not when you choose the 'loudspeaker' option this proves that the loudspeaker is either faulty or has become disconnected from the systemboard.
If you cannot hear people on a call at all it may be that you have a faulty earphone socket. Try plugging in a set of earphones to check if you can hear people when they call.
The loudspeaker is the speaker used for all the tones and sounds used by the phone. The receiver, which is a separate 'speaker' is used for listening to voice calls etc with the phone held close to the ear..
Score 1
No sounds, still
My phone doesnt make noise whatsoever and i ah bent chamged settings
do you have tutorial on how to reconnect the loudspeaker if it was disconnected from the systemboard?
Add a comment
Add your answer
Klyde Pantinople will be eternally grateful.
Past 24 Hours: 68
Past 7 Days: 293
Past 30 Days: 1,176
All Time: 6,112
