MacBook Pro models with 13" Retina displays manufactured beginning 2012.
1098 Questions View all
Plugged in USB, MacBook turned off & won't turn back on.
Hi all,
I've got a Retina Macbook (A1502) that seems to be totally dead after plugging in a USB to charge my phone. As soon as I plugged the USB cable into the port, it abruptly shut off and now won't turn on at all. I've tried disconnecting/reconnecting the battery, letting it sit for a week to totally drain the battery, multiple chargers, SMC reset etc.
I took it to the Genius Bar and was told this was a known issue but that it would cost 500$ to replace the logic board as I'm out of warranty. I know this stuff can happen, but as a student with little money I can't afford to fix it right now and I'm a bit peeved that simply plugging in a USB would totally kill the machine (the usb cable wasn't even one of those really cheap ones!). I was hopeful that it was a minor issue after reading about multiple people with similar issues that were resolved after disconnecting/reconnecting the battery but I don't seem to be one of the lucky ones. I had a glimmer of hope after the orange light on the charger came on whereas initially there was no light, but still no boot up. Anyways I'd like to ask if there's anything else I could try or if my only option is a logic board replacement. Thanks for your help.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
First try an SMC reset. Here's how:
https://support.apple.com/en-us/HT201295
This failing, and all else that may be recommended, and you do find that it needs a logic board, go for a "Flat Rate Repair". This costs about $357.00 directly from Apple. The FedEx you the box overnight. Total time is four days including shipping. Just call 1-800-MYAPPLE. Just tell them what the machine is doing, don't mention what you did to get it that way.
Score 4
Comments:
Why not mention how it got that way?
by
Add a comment
Add your answer
Jose Escobar will be eternally grateful.
Past 24 Hours: 20
Past 7 Days: 130
Past 30 Days: 575
All Time: 2,463
