The LG G2 Sprint was released in September 2013. The LG G2 is a LTE capable smartphone running Andriod 4.2.2 with a rear power and volume button placement.
7 Questions View all
Why does my phone always feel hot?
My phone is warm all the time and the more I use it the hotter it gets, it starts to get hotter once I turn it on from being completely off.
Add a comment
1 Answer
Chosen Solution
First check your phone case, is it blocking your phone from ventilating? You may need to clean the lint and debris from the case so your phone can breathe. If you are using a case that was not made for your phone, that could be your issue.
It may also be your software. Too many applications open at the same time will overheat the phone and drain the battery. Close the applications that cause the most battery drain like your GPS. Turning down your screen brightness can help as well. If you are unsure how to check your software and battery for issues, check out the LG G2 Sprint troubleshooting page(link below) for some great tips!
LG G2 Sprint Troubleshooting
Score 1
Add a comment
Add your answer
Ryan Bajnath will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 79
