Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
148 Questions View all
Horn beeps at vibration/noise.
When our '07 Dodge Caravan is parked with engine off, vibrations or sounds trigger a "beep" from the horn. Is there a way to adjust or "dial back" the sensitivity or a way to disconnect the motion sensor(s)?
Add a comment
1 Answer
Chosen Solution
@mr_fixit104 ,john, check that all door/hood lock contacts are aligned and clean, I believe if dirty/poor contact or not aligned vibration could set alarm off. From your manual,Security System Manual Override, the system will not arm if you lock the doors using the manual door lock plunger. The dealer may be able to change settings on the alarm. Link below is your manual, alarm section starts on pg. 18. Good luck.
Score 3
Add a comment
Add your answer
john will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 35
