Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
275 Questions View all
iMac has random black screens but works fine in Target Display Mode?
Hi,
I have a 2010 27" imac. It has the latest OS on it and has always worked fine. In the last week the screen has started going black randomly. If I shine a torch at the screen I can clearly see the computer is still on and working fine, just with the backlight out.
However!
I also have my gaming PC plugged into the iMac and have been using as my monitor for years. When I command F2 and go into target display mode with the PC, the imac works flawlessly as a monitor and the backlight stays on all the time.
If I swap back to the iMac the screen will be on but normally only for a few minutes before it blacks out again.
I am puzzled and hope someone out there has an idea what this could be.
Thanks in advance.
Comments:
ok checked corners - nothing set. Sleep time is 15 mins. When it happens the only way to get the backlight back on is to command F2 and back. Nothing else wakes the screen.
by
Let's try one last thing here, shutdown the system and then pull the AC cord leave it unplugged for a good 10 minutes then restart the system. Did that fix it? If not I'm suspecting the PRAM battery needs replacing.
by
Did the 10 mins thing. No change. Is there any point in restoring from an earlier backup or is that a waste of time?
by
I also noticed that the system clock reset during the 10 mins turned off. Would that indicate the battery is dead and if it is why would that affect the backlight?
by
Yes, that confirms the PRAM battery needs replacing
by
Add a comment
1 Answer
Chosen Solution
I would start off doing a PRAM reset. Follow this Apple TN: How to reset NVRAM on your Mac. See if that clears it. You also may want to look at your displays settings and hot corner settings making sure you haven't set the screen to go dark or go into sleep mode.
The fact the screen is not lit within OS-X, but is lit when you use the iMac as an external display points to a software/firmware type of issue when running OS-X.
Update (11/21/2016)
To replace the PRAM battery on this system will require pulling the logic board out. On the back side of it you'll see a silver quarter sized battery. Here is an image for reference: Back side of '10 27" iMac logic board note on the top edge the battery.
I would recommend bringing the system into an Apple authorized service center as this can be tricky if you've never gone into an iMac this far before.
Score 1
Comments:
I already did a PRAM test - should have put this in my original post sorry. Made no difference. Surely as well if the computer is in sleep mode I wouldn't be able to see the screen with a torch? It is not going into sleep, just the backlight goes off.
by
Within the display settings you can tell the system to darken the screen Vs sleep mode.
You can set the timer so the display goes out with inactivity and you could also setup a hot corner to do the same.
by
Add a comment
Add your answer
Jim F will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 43
All Time: 480
