Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Power button doesn't work anymore
Power button stopped working a while ago, so the computer was never turned off until it was on battery power and died. Now it will not turn on when I press it, i've tested both memory chips and the HD still works fine.
I don't know if this is important, but in complete silence I noticed that if I press the button I hear an ever so slight ticking noise, just a little faster than a clock (not from the HD I think) and a very very soft hum.
Any ideas?
Score 1
2 Comments
I replaced the whole top case. Problem solved. If there is a way to just replace the power button I will never know...
by
There's no easy way to replace just the power button. It pretty much requires that you damage the top case. You did the right thing by just replacing the top case.
by
Add a comment
Chosen Solution
This is a common problem. You need to replace the top case/keyboard.
Add a comment
Most Helpful Answer
If the battery completely drains it will not start with the battery in. Let it charge for 30 minutes. It sounds like you need to reconnect your keyboard to logic board cable. If this becomes disconnected the unit will not start or stop till the battery dies.
here's how to get to it: MacBook Core 2 Duo Upper Case Replacement
Score 2
2 Comments:
good start +
by
Good advice, but the battery is now fully charged and I have also already taken off the upper case and reseated the cable (should have mentioned that, sorry).
FYI also tried different combinations, with battery and AC power, only AC power, only battery.
by
Add a comment
Another option, if your handy with a screwdriver, is to try the internal power button, which actually nothing more than to points on the MLB near the fan, Depending on Generation, it will be marked pwr btn, or with the power logo. Short them with a small screw driver, see if the machine turns on.
If it does power on from there its almost always the top case that needs replaced, If it does not, then you are looking a deeper issue on the logic board itself.
Also, Does the laptop have a liquid spill in its history, Liquid is the most common killer of top cases, and if thats at fault, your issues will most likely go deeper into the unit.
Mark Grummell Indianapolis, IN
Score 1
1 Comment:
I actually tried this, but for some reason it didn't work. No liquid damage, the power button had just stopped working, after failing intermittently previously.
by
Add a comment
Add your answer
spacec0w will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 9,149
