Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
TouchID not working after screen replacement (no error 53)
Touchid is not responding or scanning no errors or failed it just doesn't scan. Any help would be greatly appreciated. ( I did forget to unplug the battery before screen swapping but i did have the device off).
Add a comment
Chosen Solution
FIXED!! i had to replace the heat dispenser plate from my original phone to the new screen and it worked!
Add a comment
if you replace the original home-button it will not work, you may want to also make sure the back-plate with it will also be on it as well. you need the original home-button and back-plate
3 Comments:
Im swapping my original heat plate right now to hopefully fix it i do have the original home button will update soon.
by
You actually don't need the original back plate but obviously need original home flex.
by
awesome glad you got it working
by
Add a comment
Add your answer
Chris Herrington will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 133
