Navibot goes to home base after seconds
Hello everybody,
I've a problem with this robot. When it starts, after few seconds it goes automatically to the home base.
I thought it was a battery problem, so I replace it, but same result...
Any idea of what the !&&* could it be the problem?
Some component to test, to replace...bah!
Thanx a lot, iFix users!
Teo
ITALY
Hi,
Is the battery showing fully charged?
Do all three button icons on the robot display come on when you switch it on?
Have you checked that the recharging button on the display panel is not sticking in the operated position?
Sorry about all the questions just trying to narrow down the problem
by jayeff
Hi Facendo una indovinare la lingua
Avete controllato che il pulsante di ricarica sul display non è attaccare nella posizione operato?
Hi Taking a guess at your language
by jayeff
Ok, now it's clear.
Yes, all is perfect, the battery charges correctly. I've also cleaned all the sensors, the dust bin, everything...
by Teo
Ciao,
Il mio unico suggerimento è ora quello di provare un ripristino e vedere se questo risolve il problema.
Con l'unità disimpegnato dal dock di ricarica, aprirlo e scollegare la batteria dal systemboard. Dopo aver isolato l'alimentazione della batteria, tenere premuto il tasto ON per circa 30 secondi per dissipare ogni potere residuo nell'unità. Dopo questo rilasciare il pulsante e ricollegare la batteria al systemboard, riassemblare l'unità e verificare se funziona correttamente.
Hi,
My only suggestion now is to try a power reset and see if this resolves the problem.
With the unit disengaged from the charging dock, open it and disconnect the battery from the systemboard. Once you have isolated the battery supply, press and hold the ON button for about 30 seconds to dissipate any residual power in the unit. After this release the button and reconnect the battery to the systemboard, reassemble the unit and test if it works correctly.
by jayeff
Nah, already done. Nothing to do...
At this point I think the solution is to throw it in the dust vbin =)
by Teo
