Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Questions View all
Why won't my battery charge
MB Looses power when running. Charging led is always on green. Changed charger, battery and DC-in board. When a charged battery is put in, it willl run (until battery is depleted). Any suggestions ?
Update (12/04/2016)
IDOR 7.518 is the given AHT mistake, a DC sensor, but what part on the mainboard escapes me. Any help towards that ? Thank you .
Score 1
1 Comment
The following is the status now: any charged battery will be recognized and will start up the mbp . Without a battery and only the charger, the mbp will not start. When battery is in and charger connected, it works fine. Coconut states that the 60w charger is recognized, but the battery is not charged.
by
Add a comment
Chosen Solution
First let's get a better idea of your actual battery status. Please download and run Coconut Battery and let us know your results:
http://www.coconut-flavour.com/coconutba...
Score 5
4 Comments:
Thumbs up to mayer
by
Will do, will have to find a charged battery first.
by
Coconut: Battery is fine, charger is 60 watts. Mac: battery not charging, powered by the charger / when charger is removed, Mac: powered by battery
by
Battery is not charged, drained empty, second battery, same result. Coconut recognizes the charger, but no charge flows into the battery. Also, wit no battery present, the charger alone won't power up the mbp or run it, when taking battery out.
by
Add a comment
I haven't heard of this problem, it could be the Magsafe port and the connection to the motherboard that is causing it to believe that it is charging. Since you did change the battery and it is older any warranty would be voided, I would reach out to Apple for advice. Try completely powering it off and disconnecting the battery connection and then re-connecting. Reboot, and see if that changes anything. Maybe try another set of batteries? Hope this helps.
3 Comments:
Had replaced the original battery with a brand new one (partially charged) worked fine. Replaced it with a third used battery, recharged from a friends PB, worked fine as well, until depleted.
by
So is the issue resolved?
by
I would listen to mayer's instructions. They have more knowledge of the problem than I do. Best of luck!
by
Add a comment
Add your answer
wolfgangschaefer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 119
