The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
92 Questions View all
Tool used to remove the logicboard and where to buy extra screws?
Is the logic board glued to the digitizer? Is that why you have to use the special tool to remove it? Also where can you buy extra screws that hold the evo together. Does anyone know what size the screws are? Length?
Add a comment
Chosen Solution
Check out the teardown - HTC Evo 4G Teardown You'll see that the logic board is only attached by a ribbon cable to the digitizer. What you need the Torx screwdriver for is unscrewing the red rear casing from the logic board. The teardown says that the screws are T5 Torx screws.
Add a comment
you can find all kind of fasterners at mcmaster car's website. Any time i need some weird type, they have it.
also look at your local harbor freight store, they have a cheap security bit set
Add a comment
Add your answer
Juan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,226
