The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3721 Questions View all
Display striped and 1/2 toucvh screen does not work
The phone was dropped. exterior not damaged.
The display is now striped vertically. The displayed images move underneath the stripes, which are broad and translucent. Image under the stripes there appear washed out.
On the right side there are narrower, darker stripes. Also on the right side the touch function does not work.
Is it likely at screen replacement would cure the problem?
Is it likely that some connection or other repairable problem resulted from the drop?
Suggestions as to how to proceed.
Thank you
Add a comment
Chosen Solution
Hello, this is most likely just a damaged LCD and should be easily fixed by replacing the LCD.
Score 2
Add a comment
Most Helpful Answer
Should just be a bad display.
iPhone 5s Front Panel Replacement
iPhone 5s LCD Screen and Digitizer
iPhone 5s LCD Screen and Digitizer Image
Product
$0
Score 2
Add a comment
Add your answer
Gary Tash will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 35
