Pilot not holding Goes out after let go the button.
Hello... trouble with the water heater.
First the pilot wouldn't lite.. so i turned it off for 10min to clear the gas and tried
it again and the pilot worked. I hold the pilot button down until the status flashes but
the pilot goes out when i let go the button. I was told there is a reset button so i pushed what i thought was the reset but it doesn't push or click. Any thoughts?
Score 1
1 Comment
Tested the Thermopile and the mV reaches above 500 mV and continues to go up after about a minute of holding down the pilot button, but as soon as you let it go it drops back down to almost nothing.
by
Add a comment
1 Answer
Chosen Solution
@cameraparts4you , Be extremelly careful working with your gas appliance, if unsure contact a Qualified Technician. Dirty TC( thermocouple), faulty TC, pilot flame to not set properly/small or not close enough to TC, partially plugged pilot tube, faulty/bad gas control valve, all could cause pilot not to stay lit. Check the attached links troubleshooting,instruction, Good luck.
http://www.doityourself.com/stry/reasons...
http://www.home-repair-central.com/gas-h...
Score 4
Add a comment
Add your answer
Sales Cameraparts4you will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 29
Past 30 Days: 89
All Time: 23,712
