Replaced LED Display Board Display won't turn off
I posted a few weeks ago about my screen flickering - was told it was the LED Display Driver Board that needed replacing - so I did - I bought 2 just in case, and the first one, no change, second one, same, no change either.
However, now the display won't turn off - ever. The computer boots up, very white screen, then goes to the gray screen and all is normal. Except - to shut down, it acts normally but then goes from black to white as the hard drive shuts down but the display stays on - all white again.
It only turns off when the battery is removed.
I have done resets (hold the power button 10 secs, remove battery etc.), restarted with the PR, Opt, Comm Keys, etc. etc., nothing seems to work.
Again - I still have the same issues with shadows so I know the LED display driver board is not working properly, I will replace it with the original one today and contact the people I bought the new ones from - but the display itself will not shut off unless the battery is removed.
If I put the computer in Sleep mode, it turns black for a split second, then flashes back to white again.
4 Comments
*update* I spoke to a fellow at the place I bought the replacement board and he said he thought it was the LED Display itself which is bad - but he also said he was clueless as to why it wouldn't shut itself off unless the battery was pulled. Maybe it's because that also kills the power completely?
Anyone here have any clues as to what's going on? or if I actually need to replace the Display? which I assume is just the technical term for a new screen?
by sunnryze
what does it take to get someone to respond??? anyone?? HELP PLEASE!!!
by sunnryze
Sorry guy some of us have real lives and we often live in a different time zone than you ;-}
by Dan
Here's the original question: 2007 MacBook Pro screen flickering, not constant
by Dan
