Why is my gas gauge acting eraticly
Gas gauge reads full then empty in secounds
@bot , brad, could be a few things causing this most likely is the fuel sending unit in the tank as GM's were bad in these years, other possibilities are bad connections, check ground/ plug at fuel pump harness under truck for loose/corrosion,burnt, or interior fuel gage could be faulty. Check the attached trouble shooting links,instruction and guides, Good luck.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 19
All Time: 465
