The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 Questions View all
Why does my heater only blow through cabin and floor vents?
2004 pontiac grand am heater only blows through cabin and floor vents, no defrost
Add a comment
1 Answer
Chosen Solution
malcolmphillips86, malcolm, Could be disconnected/broken vacuum line at the air mode door actuator or under the hood in engine compartment( you may hear a hissing sound) if vacuum line disconnected or it could be faulty/stuck actuator, or stuck/broken air mode door. Check the attached links,instruction and guides, Good luck.
https://www.youtube.com/watch?v=lPzbkBAL...
http://www.grandprixforums.net/threads/2...
http://www.justanswer.com/pontiac/73jxs-...
Score 2
Add a comment
Add your answer
malcolmphillips86 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 184
