Black lines in picture. No pictures in these lines at all
Hello,
Been trying to find info on this model for quite some time, but nobody seems to be able to.
This is a Sony DHR-1000VC. It (used to) play(s) DV and MiniDV tapes.
This is the mechanics of it
And this is the picture it gives me now for quite some time.
I found more of those problems over the net, and these appear to be gray lines. or lines in which there still is somewhat picture to be seen.
My device shows steady black lines, and in between the lines the picture is crispy clear.
Also sound hardly does a thing.
Below also a video of the issue:
Now,
Would i be searching this in a defective video head (since i've been cleaning this a gazillion times. Sometimes there's no picture when using an older tape. After cleaning, i get back to this picture)
Or should i have to look in a malfunctioning video board?
If someone can point me in the right direction, would be a great help :-)
2 Comments
Hi, Just wondering. Do the tapes record this way or are you replaying old pre recorded tapes.
Have you tried removing the tape head flex cable from where it is inserted into the motherboard and then re- inserting it to see if it improves. Got caught out once on a VCR where the 'head' cable had been pushed into the connector too far and some of the connections weren't making because of the insulation on the cable. Just a thought
by jayeff
These are tapes that have been recorded before. Tapes i know are good.
Head cable is no issue here :-)
Thanks for thinking along !
by Yves
