Released alongside the Wii console on November 19, 2006. Identified by the model number RVL-005
1 Questions View all
What type of screw is used in the end connector?
On the plug that connects this controller to the other controller, There is a clear plastic piece that is held on with two screws in a triangle shape. I need to remove this piece but I can't find a screwdriver with the correct tip to use. What size tip do I need?
Add a comment
1 Answer
Chosen Solution
Sounds like a tri-wing screw. Would you post a photo?
Tri-point Y1 Screwdriver
Tri-point Y0 Screwdriver
The Y0 & Y1 are included in this set:
26 Bit Driver Kit
Tri-point Y0 Screwdriver Image
Product
$8.99
Tri-point Y1 Screwdriver Image
Product
$12.99
Score 1
Comments:
I see I can insert a link but I don't see how to add a photo to the post. The Y0 Tri-point was correct. Thanks!
by
bryangarmon you can only add images to answers or question, not comments. Use this guide Adding images to an existing question to add images.
by
Add a comment
Add your answer
bryangarmon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 116
