Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Replaced LCD, now battery won't charge and new LCD is cloudy
I replaced my damaged display assembly and rear case w/out a problem. It powered up and looked completely fixed. Everything functioned perfectly for the rest of the day except the battery wouldn't recharge. It slowly drained. I left it on the charger over night. The next morning I pressed and held the power button and got the black screen w/ the red-level low-battery charging screen. But the top corners and side of the LCD had a white haze!! I hurriedly unplugged it and it powered off completely, presumably because of the drained battery.
So now what? Bad battery? Or did I fry something on the logic board? Have I damaged my brand new LCD screen? Any advice would be appreciated. I'm afraid to move forward until I know more because I don't want to make things worse.
Score 1
Add a comment
Chosen Solution
I've faced similar issues before, except for the haze in the corners, and tried a new battery and presto! The phone comes to life and is in business.
The batteries on the iPhones are very sensitive, especially if they've been removed for the first time. The ease of which you can damage one is just silly....it takes the right tools and patience to remove. If you can, you need to cut the end flaps connected to the underneath adhesive and pull them out from the bottom.
When in doubt, as I've had a mechanic and other fix-it type friends tell me...start replacing and fixing the cheapest and easiest stuff first. For we mobile jocks, that usually starts with a simple, an inexpensive battery replacement.
I am confident in advising that you won't cause any further damage at least, by replacing the battery.
Score 1
5 Comments:
Yup, that was it. I jacked my battery when I took it out the first time. Now it's working great. Thanks.
by
BTW, I read elsewhere on the Net that the white halo might have been caused by the LCD being overheated during the charging process. I'd love to hear more about that if anyone has some understanding of the issue. In particular, I've been wondering if there would have been permanent damage to the display eventually (like if I left it charging for 2 days). Thanks.
by
It might just go away over time. Bad batteries or batteries not plugged in properly can cause this issue. For me it was like a flickering screen burn in effect.
by
Rats. New battery, purchased from ScandiTech lasted from 11/10 to 12/3. Then it drained and when I tried to recharge it, the phone would get very hot. So hot that the white halo appeared around the screen. So on 12/3 I bought a new battery from ifixit. That one arrived on 12/6 and stopped working last night, 12/8. Same problem: battery suddenly drains and powers off. Plug in the charger and instead of charging, the phone becomes very hot.
by
After reading other posts, it seems to me my U2 IC chip is bad. Blerg. Not sure how to address this issue. It's outside my skill set.
by
Add a comment
Hate to say it, but it looks very much like a bad Tristar IC. This is not a DIY repair.
You need to find a repair shop that does micro-soldering. You can check my profile as I can do those types of repair but I may not conveniently located. Lots of shops do mail-in repairs, myself included, but if you can find someone reputable locally, that would be ideal for you.
At the very least, they can properly diagnose the problem.
Score 1
Add a comment
Add your answer
Suzanne Green will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 103
