Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Replaced touch screen of iPhone 3G, but it doesn't work
I have replaced the touch screen of iphone 3g, but there is the left part of the touch that doesn't work. what I can do? there is a warranty?
Ps: when I open the box the front panel was chipped below the home button.
Score -1
1 Comment
This question was migrated from http://meta.ifixit.com/.
by
Add a comment
Chosen Solution
try hard reset or reopen phone when off and check connector 3 for damage and also in properly
Score 1
3 Comments:
Hold both the sleep/wake and Home buttons together for at least 10 seconds.
The red shut down slider will show up at the top of the screen and then disappear. Keep holding the buttons. The screen may even go black, but don’t let go of the buttons until the Apple logo shows up. When it appears, let the buttons go and the phone will start up normally.
by
What about a broken digitizer? "front panel was chipped below the home button" could that not lead to a broken digitizer?
by
yes I think you are correct my friend, I think I posted the hard reset as a first step and was waiting to hear back.. the next step would be what you have suggested oldturkey
by
Add a comment
For the touch screen, you can check wether the home button flex cable was too loose or what. If there are very dirty, you may need use a little alcohol to clear it and retry again.
Hope everything will goes well!
Score -2
4 Comments:
-1 the problem is the touch screen, not the home button.. none of your answers have been particularly good. or correct.
by
pollytintop,yes, I know it is the touch screen. But the home buttom flex cable too dirty or loose will influence the touch screen either.
by
You think dirt may lift the bottom portion of the screen up and lose contact?? I'm not sold but if it works then youre right and I apologise. Let's see..
by
-1 a dirty or improperly seated connector would not lead to a partially functioning digitizer.
by
Add a comment
Add your answer
obbe87 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,556
