The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
114 Questions View all
Z3 Flex connector mismatch
I have an Xperia Z3 to repair but it looks odd to me. The signal flex cable was damaged and I have sourced a replacement but both the new and old cables seem to have female connector ends. This would be ok but the two board connector sockets would then need to be male and only one is. Am I missing something here or is the a missing adaptor of sorts?
Thanks
Brian
Add a comment
1 Answer
Chosen Solution
Hi
Don't know if this is a help or not but here is a link to a video showing the complete re assembly of a Xperia Z3.
At 4:40 minutes onwards into the video there is a clear view of the signal cable connector on the boards at both ends. To me it appears that both are male connectors, as you can see what looks like a centre pin in both the connector plugs on the boards. Hopefully your connector is not broken.
https://www.youtube.com/watch?v=iFlaXdq3...
Hopefully this is of some help.
Score 2
2 Comments:
Thanks I watched that. I appears that the male connector was actually no longer there so I took one from another faulty Z3 component and soldered it on. Phones working now thanks
Brian
by
Just to be clear this was actually an antenna cable and not a ribbon flex cable right?
The antenna socket on the logic board or antenna daughter board that mounts onto the bottom speaker thing can rip off easily if cable is not unclogged properly.
by
Add a comment
Add your answer
Brian Franklin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 141
