brake lights dont work on 1996 chevy s 10
why brake lights dont work
Ok lets start with the obvious , check the fuse , if there ok then check the brake light activation switch under the dash on the brake pedal shaft, still no joy then break out the test light and follow the wiring and look for lose of power. Check the bulbs and sockets also check your ground is good . Hope this helps
did all this is there a relay
this forum may help http://www.truckforum.org/threads/1994-c...
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 665
