Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4605 Questions View all
iPhone 6 not picking up signal help
i have an iPhone 6 that is not picking up any signal. It recognizes when the SIM is inserted but just either says searching for awhile or goes straight to no service. I tried multiple SIMS and tried calling the carrier "611" but goes straight to call failed. I reset the network settings and took the phone apart and checked that the cellular charging port antenna was on good and I also replaced the back housing to a new one just in case it was the problem but it still didn't help. Its running the latest iOS and has been restored. I also changed the charging port/antenna. Any other suggestions ? also what all pieces are part of the cellular antenna? wifi works fine on it.
Score 2
Comments:
what happens if you dial *#06#?
by
When I type it in it just disappears and stays on the dialing screen instead of displaying the IMEI
by
Is there IMEI number displayed in settings > general > about phone?
by
You thinking baseband?
by
Yep. Don't want the OP to restore his phone and end up failing restore and end up with a dead phone if the baseband chip has issues.
by
Show 2 more comments
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
I've recently fixed this by replacing the antenna switch. Rf5159 is the part number.
Add a comment
Add your answer
CAB will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 155
