Coffee brewer released in 2013. This specific Keurig can be identified by its model number K70 listed on the bottom plate of the brewer and is a single cup brewer.
5 Questions View all
Why does my coffee taste bad?
The coffee I brewed in my Keurig has a bad taste to it and I noticed some small beans in the cup as well. I've been using this model for years now and recently I've noticed an unusual taste to the coffee.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
If your coffee has a metallic taste to it or has coffee grounds in the cups, then the Keurig will need to be cleaned. To clean the brewer, fill the water tank on the left side with a mixture of white vinegar and water. Now keep making hot water with the Keurig so that the mixture keeps going through the system. This should get rid of any build up inside it.
Score 1
Add a comment
Add your answer
michelinval will be eternally grateful.
Past 24 Hours: 31
Past 7 Days: 119
Past 30 Days: 595
All Time: 2,403
