How can I fix alcate fall wate
How can I fix alcate fall water
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Abdul Ahmed I'm assuming you dropped your phone in the water . You will need to take your phone apart and clean it with 90+%IP alcohol . Use a soft tooth brush on the motherboard and all connectors . Replace the battery as it will be garbage. this is a good source for further instruction
Electronics Water Damage
If you have problem with English use google translate to help .Hope this helps.
Score 2
Comments:
@jimfixer Hey, how do you think amusing will translate ;-))
by
@mayer probably not as funny as it sounds I speak good engrish :-o. I'll fix that
by
@mayer Did you remove my edit option here
by
@jimfixer No. and mines gone too. I noticed this just this morning. Would you care to post it on Meta?
by
@mayer @jimfixer. you can only edit comments within a certain timeframe. It is not new, this has been going on for a while.....:-)
by
Show 2 more comments
Add a comment
Add your answer
Abdul Ahmed will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 58
