Uniden model is G955. The serial number is H06311657. This is a 9" LCD monitor that is used for surveillance purposes that comes in a package with 2 wireless cameras.
6 Questions View all
Why does my monitor make bad sound?
When I try to play audio from my monitor, the speaker produces distorted and low volume sound. What can I do to fix it?
Add a comment
1 Answer
Chosen Solution
Your problem is likely due to some kind of damage to the speaker, which makes the sound muffled or distorted. You will need to replace the speaker.
If the speaker is replaced and you are sure that you have installed it correctly, but the sound is still low while volume is set to the maximum, your battery could be weak. Check out the monitor's Troubleshooting Page for further help.
Score 1
Add a comment
Add your answer
Sundus Al Shibani will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 70
