The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3720 Questions View all
"Cannot active Touch ID" After charger port replacement.
Did a normal charger port replacement for an customer (iPhone 5S Black)
After the replacement its plays sounds, charges, microphone and mini jack all works.
But it shows the following message
Translated "Could not activate touch id on this iPhone"
The home button ( the button and the touch id) does not work.
No visible damage to either charger module or home button flex.
Suggestions?
Charger port bad? High copy aka no support for latest IOS?
Add a comment
1 Answer
Chosen Solution
Have had this problem before when replacing the charger port before, was a faulty part. Try the old one (if it is just not charging), and if the home/touch id is working, it will need a new charger port.
Score 1
Add a comment
Add your answer
melvin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 345
