2.3L 4cyl or 3.0L V6, 6th Generation
334 Questions View all
Where is the temperature sensor in a 99 accord
Hi good morning, my car would not check the temperature, which is not bad, that is not heated, but I want the temperature indicator that works well, I want to know where in the motor is located to change ...
use a translator that not speak English if not well understood : b
Add a comment
1 Answer
Chosen Solution
@normaluna , Norma, on the 2.3 engine temp. sensor is by the distributor in the thermostat housing, on the 3.0 engine follow the upper rad hose to the intake and the sensor is just above the hose screwed into intake manifold.
Links below have pictures of the temp. sensor locations. Good luck.
https://www.2carpros.com/questions/1998-...
http://www.justanswer.com/honda/7e9vy-ac...
Score 2
Comments:
Thank you very much for the help
Salu2:)
by
Add a comment
Add your answer
Norma Luna will be eternally grateful.
Past 24 Hours: 18
Past 7 Days: 111
Past 30 Days: 495
All Time: 6,230
