MacBook Pro models with 13" Retina displays manufactured beginning 2012.
4674 Questions View all
Black screen, until lit is almost closed
Hello iFixit.
I replaced my screen on my Macbook Pro, and when i set the new screen in and power on, I hear the startup sound, but just black screen. When I try to close the lit, 2cm from totally closed it turns on, and then works fine.
I have tried:
Resetting NVRAM / PRAM
Resetting the “SMC”
Start up into Safe Mode
Edit:When i log in and try to put into sleep mode, it works fine. It seems like it's only on the login screen.
Add a comment
1 Answer
Chosen Solution
Could be a bad LCD cable or a faulty LCD panel ribbon (sometimes the picture can cut out at certain angles), I would recommend trying the old screen to see if it is fine. Also try running a magnet along the left side of the palmrest (to the left of the keyboard along the top), to see if the screen tries to turn on. When the Macbook detects a magnet in this area, it thinks the lid is shut (so it will turn the screen off), this could be the problem?
I would most likely say a faulty LCD assembly though. Try your old one and see if it is fine.
Score 1
7 Comments:
I have tried the old screen, and it's the same.
When i run a magnet at the ESC button the screen starts up as normal.
by
And on normal use it works just fine.
by
I would recommend testing the screen when not screwed into the palmrest area, to see if it works fine. Sounds like an issue with the hall sensor/sleep sensor.
by
I tried the flash light test, and it showed my screen.
by
Sorry, do you mean you put a flash light to the screen and could see a dark image? There is a signal on the logic board SMC_LID which dims the screen when it thinks the lid is shut. I think this part of the circuit is the issue (or magnet interference), but I am not sure without looking at it.
I would recommend taking it somewhere who can look at this and professionally diagnose the logic board, it sounds like that is where the fault is.
by
Show 2 more comments
Add a comment
Add your answer
Per Eckholdt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 627
