Laptop freezes after few minutes of starting up.
I have an HCL laptop which on startup freezes completely. Following is what happens:
- The start button is pressed and the laptop switches on...
- The laptop surpasses the BIOS screen...
- The laptop is dualboot b/w Ubuntu and Windows, I can choose either...
- It will work for 10 mins maximum and freeze (screen freezes, nothing else works)...
Need help...
2 Comments
Hi,
Has the CPU or chipset been overheated in the past?
If you have 2 sticks of RAM try either Memtest 86 to test them or remove 1 stick at at time and see if it occurs.
by jayeff
hello , try removing some start up program using task manager and check to see if it a hardware problem . for any other software issue follow the post http://fixingblog.com/top-10-tricks-quic... . see if any of that solves the issue .
by Jismy chacko
