Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
iPhone 5s won't power up after battery and home button replacement.
I replaced the battery (plastic tabs broke, so I heated to warm and had no trouble getting it out without serious prying necessary); broke the home button cable getting the phone opened (Grrrrr), so got a new one and replaced it. Everything seemed to plug in fine; felt the nice little tiny "snap" thing with each re-attachment of cables. I've plugged it in to charge, but after many minutes, nothing.
What are the most likely things I'm looking at now? It would be great if I had some idea what is most (and next, and so on) likely to be the problem.
Thanks!
Judy
Score 1
4 Comments:
It does seem to be charging; the phone is slightly warm after being plugged in for awhile.
by
try holding home and power until the apple logo appears. If that doesn't work, plug it into your computer to see if iTunes sees it.
We're trying to figure out if its the phone or the display that isn't working.
by
Is it drawing power from the charger? If so how many amps?
by
iTunes does not see it, Josh.
Ethan, how do I determine that?
by
Add a comment
1 Answer
If a battery has been disconnected for an extended period of time--like sitting on a warehouse shelf--It may need to be "reset" using a tester/charger. I have had good luck so far with this one: Kaisi® Battery Tester/Charger Activation Board for Apple Phone 4/4S/5/5C/5S/6/6s/6+/6s+ (12PCS) https://www.amazon.com/dp/B019UE4PW0/ref...
There may be other ways of "resetting" batteries as well--hope this helps.
Add a comment
Add your answer
Judy Ditmer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 80
