Released during the previous decade, the Toshiba Satellite C650D’s most distinguishing features are its black, textured casing and its keyboard, which includes a number pad.
6 Questions View all
What can I do if my daughter wasted water on it?
My daughter placed a cup on top of the laptop. She didn't know it had a hole in it and the soda can out. It works but nothing is on the screen. What can I do?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the laptop's operating design and could damage the components.
First do not turn on your laptop and then you need to remove the battery as soon as possible from the laptop to minimize further damage.''
Then you need to dis-assemble the rest of the laptop and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Here is a link to the Ifixit guide on how to dis-assemble your laptop.
Hopefully after you have done all this the laptop might possibly work correctly again.
If this process seems too daunting, take your laptop to a reputable, professional computer repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 5
Comments:
Thanks so much. This information was quite helpful
by
Add a comment
it easy pull out the motherboard remove the cpu every thing fan brush the mb with alcohol and let it dry
then test
Add a comment
Add your answer
Deborah Shepherd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 60
