Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
456 Questions View all
Boot problems! Will only start up after the third attempt?
I have a weird issue with a 24" Imac. When I plug the computer in the first diagnostic led is on when I press the power button I get 3 lights hear a half chime and it stops. All lights go out including the first light. I unplug it plug back in 1st light comes back on, press power and get 3 lights again and the half chime all go out.
The third time
I unplug and re plug again 1st light comes back on but this time it boots right up all lights full chime and screen comes on.
At first I thought this was a power supply issue but wouldn't the first light stay off when I unplug it a re plug in if it was the power supply?
After I get it to come on the third time, I can turn it off an on normally until I unplug it and let it sit for a while. Then I have to do the 3 time unplug deal.
I have replaced the Pram Coin battery, and reset the pram.
Any Ideas what might be causing this?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
I do a reflow on the GPU or replace it.
Score 3
Comments:
Thank you I will give it a shot. So since the 1st light comes back on when I unplug and replug it should be fine?
by
All that fire light tells you is that the power supply is at least getting trickle power. I really dosen't even tell you if the supply is good.
by
Add a comment
Add your answer
LEFHANSEF will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 71
