iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Questions View all
Processor upgrade on an iMac 27" that already has i7?
Hi. I have a late 2009 iMac fully specced with i7 from apple when it was new and i have upgraded the ram from 8 to 16gb. It is starting to be a bit slow, so i would like to upgrade the processor. Any suggestions? I want the best possible one.
Add a comment
1 Answer
Chosen Solution
The best CPU this series had was the i7 2.8 GHz. There really isn't anything better that will work in your system.
How about focusing on doing some house cleaning on your hard drive instead. A slow or sluggish system is one that needs some drive TLC!
  • Clean out all of your old stuff you don't need any more (back it up)
  • Clear out the old caches & log files. I find this tool makes quick work of it: Disk Doctor
  • Run Disk Utilities to check your drive (from an external bootable drive) to make sure the drive is healthy
  • Either scrub the drive down (back it up & reformat it, then restore your stuff back on. Or better, use a good drive defraging tool like this one: Disk Genius.
The last thing you might want to consider is to install a second drive (SSD) in this case make it your boot drive and leave your old internal as the data drive. Here's the IFIXIT guide to do this: Installing iMac Intel 27" EMC 2309 and 2374 Dual Hard Drive.
And the last possibility here if you don't want a dual drive setup is to upgrade your HD to a hybrid drive (SSHD). Here is what I would put in: Seagate Desktop SSHD. You'll also need this: OWC In-line Digital Thermal Sensor for iMac 2009-2010 Hard Drive Upgrade and lastly, here is the IFIXIT guide: iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement.
iMac Intel 27" EMC 2309 and 2374 Hard Drive Image
Guide
Difficulty:
Moderate
40 minutes - 2 hours
iMac Intel 27" EMC 2309 and 2374 Dual Drive Image
Guide
Installing iMac Intel 27" EMC 2309 and 2374 Dual Drive
Difficulty:
Moderate
1 - 2 hours
Score 1
Add a comment
Add your answer
Anders Jamissen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 106
