Fix Your Stuff
Right to Repair
Store
Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
5183 Questions View all
Loose-ish Home button after Front Panel Replacement
Hi,
I just replaced the front panel of an iphone 6 (space grey), and everything works fine, except for the home button being slightly loose. There is some wobble room and putting your finger on it you can feel the slight movement.
Is this a problem that can be solved by buying adhesive replacement?
Score 2
Add a comment
Chosen Solution
If you are referring to the home button gasket here then yes:
iPhone 6 and 6 Plus Home Button Gasket
iPhone 6 and 6 Plus Home Button Gasket Image
Product
$5.99
Score 4
Add a comment
This can also be down to the fact that the glass isn't right. Copy screens use thin glass and sometimes have to add bits of plastic to make the home button sit right
Score 2
Add a comment
Trust.. The best thing to do is cut a piece of sticky tape out (the size of your home button, or maybe just a tiny bit bigger) if your pro, stencil a circle shape out and place it over your home button, it will make your home button kinda like the iPhone 7, it's a quick easy fix until a new gasket or home button is provided. you’ll thank me later ;)
Score 1
Add a comment
Add your answer
mbarthet3 will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 58
All Time: 12,861
