The Fitbit Surge was released in 2015 and is identifiable by model number FB501BKL. This is a smartwatch that is capable of monitoring your heart rate, pace, elevation, and distance.
20 Questions View all
Water went inside my fit bit surge And it's not workin
Please help me how to fix my Fitbit surge . Can it be repaired or do I need to buy new one
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Original: First step, leave it in a sealed container filled with uncooked rice for 12 - 24 hours based on how much water went inside.
Uncooked rice is a desiccant that removes water from everything around it.
Edit: Apparently while rice will remove the water, it can damage the device in the process. Here is a guide to doing it properly: Don't Put Your Device in Rice. Here's Why
Comments:
Hi @salemcve ,
With electronics and water the first thing to do if possible is to disconnect the power source from the device.
This may also be of interest to you.
by
Thanks @jayeff ! I did not know that.
by
Add a comment
Add your answer
Sanya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 187
