2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
404 Questions View all
My rMBP doesnt increase fans automatically.
Even in CS:GO. Sensors seems ok. I did SMC reset. Also did clean install. I can increase fans manually. My rMBP is rMBP (Mid-2012) and os version is 10.12.1. You can watch here https://www.youtube.com/watch?v=vQdviYOW...
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
The fan control is kind of different on Retina MacBook Pros for some reason, the SMC waits a while until kicking in the fans to high gear to cool down the laptop properly. The temperature isn't being increased very high by the testing program you're running. MacBook Pros usually go up to 105 C before throttling - try running Furmark for a long time, and if the fans stay at ~2000RPM even if the processor temperature reads over 95, then you may have a SMC or fan controller problem.
Score 1
Add a comment
Add your answer
Ali Celik will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 54
