Why am I still having issues with ice build up?
We have a whirlpool french door fridge/freezer, we have been having issues with ice build up on the back panel in the freezer, we have replaced the thermostat and just last week we replaced the control board, here we are a week later and it is making the loud noise with the build up in the back panel of the freezer again. What else can we possibly need to fix to resolve this issue?
2 Comments
Hi, What is the model number of the fridge?
Could be the defrost heater is not working. Is the fridge (not freezer) temp OK or is it warm. If it is warmer than it should be it may be that the evaporator fan is not working, due to ice build up or if ice free it may not be working. Can you hear a fan running in the fridge, not at the outside (at back) of the fridge that is a different one, when the door is closed? It should run when the door is closed to get the temp down to the desired level but stop when it is opened to prevent cold air being blown out through the open door.
by jayeff
Model Number is WRF560SEYW04.
Yes I can hear the fan and gets really really loud until the freezer just stops working. The temp of the fridge is fine until it stops running, I do notice that as it continues to get louder and right before it goes out it will start to be not as cool in the fridge area.
Repair men said that if it was not the thermostat, not the control board, that now it would and could only be the wiring in the fridge. I just find that hard to believe it does fine after defrosted for about a week, and then the ice returns and the noise it makes just gets louder until it stops.
by marjiemoricals
