Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
turn on a pcb iPhone 5, only with the screen
hello, how I can turn on a pcb iphone 5, only with the screen and the pcb connected to a jumper powersupply what is necessary to unite?
Thanks
Score 1
4 Comments
You connect the negative and positive to the battery terminals to start the phone up automatically. It will turn itself on.
by
what you say is not true. if you connect a power supply to the iphone, if the power button is pressed not start the pcb iphone.
In many videos do a Juper with tweezers and the phone starts that's what NEEDS to know is which esl jumper on without power button.
https://youtu.be/aMPrOmlULuo
In this video the technician is testing a power supply 5c and until you press the power button and the phone starts brand or source consumption by what you say is not real.
a greeting
by
Well you won't kill the phone shorting the power button pins on the board, just keep trying to short the pins for lock button connector until you find the right combination.
by
Esta es la solucion, solo hay que poner el pin 2 del conector de power a masa y ya enciende.
Un saludo a todos
by
Add a comment
1 Answer
Chosen Solution
Un saludo a todos
Os pongo una foto para que se vea más claro
Score 2
Add a comment
Add your answer
calyd3 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 164
