A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1695 Questions View all
How do I fix a bent USB pin on my PS4?
One of my PS4's USB ports is loose and doesn't charge controllers unless I hold the USB cable and angle it upward.
I've looked inside the port on the from of the PS4 and the 4th pin, furthest to the right is bent upward.
I've tried to stick an iPhone sim tool in there but there's no way I can get underneath the pin to angle it back down.
Is it an easy fix just to replace the whole USB port?
Score 1
Add a comment
1 Answer
Chosen Solution
Unfortunately, this is not an easy fix. The only good way to fix it permanently is to replace the USB port. Both ports are molded together and are soldered to the motherboard so the only way to fix them is to desolder them and solder in new ones. I've done a couple of these but it would not be a repair that the average person could do.
Score 2
2 Comments:
Exactly - the only permanent solution is USB port replacement. You need some special tools and magnifier at least ( microscope is preferaed). not an easy fix and definitely not recommended for beginners.
by
Thanks for the info guys, I'll just have to swap out between my VR and charging controllers
by
Add a comment
Add your answer
Pietro Di Meglio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 6,947
