Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1351 Questions View all
Why are the on screen buttons not working on my iPhone.
Last week my my phone got a little damp while i was fishing. It never got submerged, just damp. When i pulled it out of my pocket to use, the screen has some moister on it. The phone turned on but the screen was moving all around, changing colors and had lines all over it. I went home and put it in a bag of rice assuming it would help pull any water out. 3 days later i pulled it out. The phone turned on and asked me to put in the passcode. I could see i was receiving texts and connected to the network. The screen looked okay but had two lines down the middle. None of the passcode buttons worked and i couldn't swipe left. How do i fix this?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
Open up the phone and clean the ribbon connectors / flex cables including connectors on logic board and components with 99% isophryl alcohol.
Score 2
Add a comment
Most Helpful Answer
Ben could be right. Simply giving the phone a good cleaning, could solve your problem. If not
Parts
iPhone 6s LCD Screen and Digitizer Full Assembly - Choice
Labor
iPhone 6s Display Assembly Replacement
Score 4
Add a comment
It appears that you need a new screen. They are expensive.
Also take the advice of the previous answer about cleaning with alcohol.
Add a comment
Replacing the screen may not work, the touch sensors cannot be damaged by water.
If you put a water damaged phone in rice for 3 days, the board are very likely to be damaged by now. Clean the board, if you can't do it, ask a professional for help.
Add a comment
Add your answer
cameron gunn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 175
