The side wheel is spinning backwards, how do I correct this?
The side wheel on my Roomba is spinning backwards, how do I make it return to its correct orientation?
The most common problem is an obstruction preventing the wheel from turning the correct way. The obstruction will need to be removed. The faceplate will need to be removed to fully access the wheel. Once the obstruction is cleared, the wheel should return to spinning the correct way. More details may be found here
The most common problem is an obstruction preventing the wheel from turning the correct way. The obstruction will need to be removed. The faceplate will need to be removed to fully access the wheel. Once the obstruction is cleared, the wheel should return to spinning the correct way. Additional information can be found on the troubleshooting page.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 73
1 Comment
Student question
by mayer
