Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
554 Questions View all
1 GB to 2x 2GB, it doesn't work, why?
i try to instal a 4 GB ram ( 2GB each) but it won't start.
my ram spec was DDR 2 2GB PC5300 667 MHz.
went i instal both 2GB ram the imac wont start at all, but went i replace one of them with the original 1GB ram it start and the imac reads 3 GB ram.
how to solve this problem?
Comments:
still no answer for this problem
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
http://support.apple.com/kb/HT1423
Score 2
Comments:
PC2-5300 Unbuffered Nonparity 200-pin 667MHz DDR2 SDRAM my RAM already have that kind of spec, it still won't show the apple logo if i put both the 2GB RAM
by
Try installing each 2GB sticks in each on the slots one at a time to see if you have a bad slot or bad stick. Do you get any beeps or flashing lights when trying to start up?
by
1. i try instal both 2GB, it just make the disk drive to power up.
2. i try instal just one of 2GB ram in both slots, the indication still same with case 1.
3. i try to combine the 1 GB (original RAM) and 2 GB ram, it works fine, the apple logo appear and i check it reads 3GB rams.
by
ONE AT AT TIME. Take one of the two GB sticks and insert it then try starting up. Now move it to the other slot and try starting up. Check to see what the info says is installed each time. Now do the same with the other stick. You may have a bad stick or a slot that will only read 1 GB. Are you sure the RAM was made for MAC?
by
it doesn't work, well i guess it will only work if it had 1 GB installed first, if i try 2 GB only, it still won't start at all
by
Show 2 more comments
Add a comment
The same problem happened to me a few months ago. I paniced, then thought:
Try resetting the PRAM. To do it, boot your computer holding 'alt + cmd + p + r' until it chimes three times (with an interval of time and some screen activity between them). Your computer should boot effectively now.
Add a comment
Add your answer
andika Suhendar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,549
