The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3537 Questions View all
My iPhone sometimes charge sometimes no + non working home button
Hello everyone!
As the title say , I have those problems:
-my iPhone home button don't work
- I can charge it continually because sometimes show in charging but the % don't raise up.
All those problems come after a battery replacement
Comments:
Did you replace the battery or did someone else did?
by
By myself , I did it many times
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
Gas gauge is a possible culprit yes.
Bad battery too. Those are very common.
And the home button flex cable either got damaged during the repair, or was not seated back properly. If it was damaged and replaced, you an get back home button function but not Touch ID function.
Additional troubleshooting:
You can also check if the charging dock is clogged with pocket lint.
And you may have Tristar (USB logic IC) failure. This is one of the reasons behind bad battery autonomy. Though an old device like this one can simply have had a failed battery.
Score 1
Add a comment
Most Helpful Answer
You damaged the board when trying to disconnect the battery, some tiny resistors got knocked off the board.
Score 1
Comments:
Fl 11? I want to bring it to a tecnician... How much will cost?
by
Depends on the technician. If you'd like one near you, check my profile. There is a website with a number of tried and tested technicians who can repair for walk-in as well as mail-in customers.
by
Add a comment
Add your answer
Ferdi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 70
