Blu Ray Not Accepting Disk
PS4 not accepting or ejecting disks. Drive still recognizes disks while using manual eject screw and will play them. Swapped for identical Blu Ray drive and it is exactly the same. Still wont accept or eject disks but can play using manual eject. Also, I rebuilt the database and updated the system. Did not initialize. Totally got me stumped...
2 Comments
What does the ribbon cable look like that goes from the motherboard to the disc drive?
by TronicsFix
All are in perfect condition. Ive found that if I put a functional blu ray drive in with a new PCB, it will eject and take discs. It's not married tho, so the games wont play. What I'm wondering now, is if the PCB has internal memory. A new PCB and Blu Ray drive fixed the eject issue. Then I used the existing PCB from the console & new Blu Ray drive which then still wouldnt eject or take discs, I think that the issue may be a bad PCB. At first I thought, maybe if I initialize the PS4, that may solve it. After realizing that the issue is coming down to the PCB board, I have doubts now. UNLESS, the PCB has an internal memory and needs to be wiped, which I would only know from initializing. If thats not the case, initializing and wiping the HDD will do nothin. The bad signal is not coming from the HDD/motherboard since it worked with a new PCB and drive but not with a new drive and original PCB. All I need to know is if the PCB has some sort of internal memory that could/may have become corrupt at some point.
by Gabriel
