The Shark Rocket HV301 is the second installment of vacuums in the 300 series. It is a two-in-one vacuum that comes with several attachments, making it capable of cleaning on different surfaces. Its sleek and lightweight design make it easy to maneuver around any household.
11 Questions View all
What do I do if the device won’t turn on?
My device is plugged in but will not turn on; what do I do?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Hi, if your device isn’t turning on you should try a different electrical socket to see if it could be an electrical problem. If it still doesn’t turn on, try waiting 30 minutes to see if the vacuum has just overheated. If you’re still having trouble, it is likely that your power cord has malfunctioned, so you may need to replace it.
Add a comment
Add your answer
Shelby Baccala will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 17
All Time: 166
