0.622kg (1.4 lb) tablet with a 10.8 inch display and 3 position kickstand released by Microsoft on May 5, 2015
19 Questions View all
How to replace a charging port?
My cable fits loosely in the port, It must be racked to make contact to charge.
Score 2
Add a comment
1 Answer
Chosen Solution
@creat200 The 1 st link is a tear down of the MS3 and show how you can access the port and change. The second link is good info. on problems and solutions why the MS3 may have problems charging when plugged in. Check the attached links,instruction and guides, Good luck.
Microsoft Surface Pro 3 Teardown
Score 4
Link is for Surface PRO 3, not Surface 3. The teardown is a bit different, as is the charge port.
Add a comment
Add your answer
Art Vaitl will be eternally grateful.
Past 24 Hours: 20
Past 7 Days: 131
Past 30 Days: 662
All Time: 5,403
