RCA Android tablet with detachable keyboard, identified by model number RCT6303W87DK.
261 Questions View all
What is this wire for?
I'm not sure if i can just peel back the sticker this is on at solder point 2, also im not sure why solder point 1 has two parts that are soldered....
also what is this wire for anyhow. thanks
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
It's hard to see perfectly from the picture but that appears to be a piece of coaxial cable that connects the wifi module to the wifi antenna.
The two solder points at location 1 are for the coax shield and the inner conductor itself.
That "sticker" at Location 2 is the wifi antenna. Not sure what your options are, but I would unsolder at the board. Don't peel the antenna up. If it tears, your wifi reception will be diminished.
Score 3
Comments:
After alittle more research i found that the "sticker" was more important than just holding something down. i used my spludger to carefully pry it off similar to the techniques used for the iPhone home button.
sorry for late response, i forgot i posted on here for that. thank you for the info though. good to know.
by
Add a comment
Add your answer
gagebowser55 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 139
